17 years agoBoot failures when zImage size goes a little over 3MB?
Has anyone else seen an issue like this? A zImage that's 3.0MB (4.6MB uncompressed), the kernel boots without fault. The vmlinux image, when stored as a u-boot uImage also boots. When ...
17 years agoFinally, back to this issue...
When I change the link address offset for booting to 0x00800000, zImage still wont load. Also, the corresponding linux-2.6.x/vmlinux image wont load from gdb/insight nor when wrapped in a uImage for u-boot. It's consistently hitting the BUG(mm == &init_mm); line in linux-2.6/kernel/fork.c:__mmdrop. In this example, it's the initramfs being bigger that's preventing bootup (but turning on UBI and other kernel features causes it as well): Will load: vmlinux: 26028261 zImage: 3016537 System.map:__initramfs_start: 0x052919b8 System.map:_end: 0x05454575 Wont load: vmlinux: 26115445 zImage: 3117081 System.map:__initramfs_start: 0x052919b8 System.map:_end: 0x0546cf75 Any other ideas? For PowerPC, they suggested increasing the initial memory map size. I haven't figured out the nios2 equivalent yet.
