KAbde4
7 years agoBoot fails from EPCS
Actualy I’m using hardware card based on Cyclone 10LP FPGA for my project. I'm using to try to develop a small test program. on the platform designer i used the "Serial Flash Controller Intel FPGA ...
- 7 years agoHi I followed these steps, but I modified the second. “2. Click on HEX data->properties ->select absolute addressing” instead of “Click on HEX data->properties ->select relative address and set it =auto” and also putting the right address on reset vector offset now the NIOS boot correctly. Thank you Anand for your help. Best regerds
KAbde4
7 years agoHi ,
I loaded the file .jic, unfortunately it is the same case as before.
Best Regards
