KAbde4
7 years agoBoot fails from EPCS
Actualy I’m using hardware card based on Cyclone 10LP FPGA for my project. I'm using to try to develop a small test program. on the platform designer i used the "Serial Flash Controller Intel FPGA ...
- 7 years agoHi I followed these steps, but I modified the second. “2. Click on HEX data->properties ->select absolute addressing” instead of “Click on HEX data->properties ->select relative address and set it =auto” and also putting the right address on reset vector offset now the NIOS boot correctly. Thank you Anand for your help. Best regerds
AnandRaj_S_Intel
7 years agoHi,
Please test attached file.
Steps:
- Select programming file type .jic
- Select flash device EPCS16
- Add flash device 10CL025Y
- Add sof file
- Add hex page and file
- Click on SOF data ->click properties ->select page=Page 0 and address mode=auto
- Click on .sof file ->properties ->enable compress option
- Click on HEX data->properties ->select relative address and set it =0x08000
- Click generate
Anand
