KAbde4
7 years agoBoot fails from EPCS
Actualy I’m using hardware card based on Cyclone 10LP FPGA for my project. I'm using to try to develop a small test program. on the platform designer i used the "Serial Flash Controller Intel FPGA ...
- 7 years agoHi I followed these steps, but I modified the second. “2. Click on HEX data->properties ->select absolute addressing” instead of “Click on HEX data->properties ->select relative address and set it =auto” and also putting the right address on reset vector offset now the NIOS boot correctly. Thank you Anand for your help. Best regerds
AnandRaj_S_Intel
7 years agoHi,
Re-Check the steps and file used for creating .jic.
Attached the example project. compare the map file for debugging.
If possible please attach the .map, .sof and .hex file.
Anand
- meenalkb5 years ago
Hi, I am in a similar position, trying to boot from EPCQ memory. I tried this example you attached, but you haven't set the .text section to PERIPHERALS_EPCQ64_AVL_MEM. So this example doesn't apply for Execute-in-Place, is that correct?
