21 years agoBoot errors
In trying to get the new distro to load and run, we see boot errors about "attempting to access beyond end of device." We have a 16MB device on the board (8Mx16) that is directly supported by NIOS2, ...
21 years agoAny chance that these "changes" are documented somewhere? I suspect that more of these undocumented "changes" are causing our boot problems.
Note: changing the target board to the Altera 1C12 Board Support option made it almost, sorta boot. Once. Choosing the Microtronix boards did nothing. The one time it did sorta boot I set up the eth0 interface and pinged my router, which responded in 0ms. I was hopeful, but the level-3 MTD diagnostic messages were annoying - back to the IDE. I changed the configuration to eliminate the MTD debug messages (note - that's the only change I made.) After recompiling and uploading, I was dead in the water. And when I say "dead" I mean "not a single message" dead. Very bad. So I put the debug messages back in at Level-1 and reloaded. Now it booted, but crashed with an "attempt to access past end" message just after announcing the preemptive scheduler. So I put the debug messages back in at Level-3 (just like when it booted that one, lone time) and reloaded. Now it booted, but crashed with an "attempt to access past end" message just after announcing the preemptive scheduler - same symptom as the Level-1 debug messages. So, if anyone can provide a list of configuration changes, I think we could sort this out. Short of that, I have to give this release a huge thumbs down. It just doesn't work. When are some patches due?
