20 years agoBoot 2 CPUs form EPCS4
I have a Cyclone2 with a external Memory an a serial Flash(EPCS4) I have 2 CPUs(cpu0 and cpu1). Is it possible to boot cpu0 and cpu1 from EPCS4?? If yes: how do I have to programm my 2 *.elf ...
20 years ago --- Quote Start --- originally posted by kistler@Aug 17 2006, 02:36 PM i have a cyclone2 with a external memory an a serial flash(epcs4)
copy the firmware_cpu1 after cpu0 has boot to ram and start it in a easy way? --- Quote End --- Do both CPUs share the same RAM? You could add a small onchip memory with reset code (embedded in the FPGA configuration) for CPU1 where it waits after reset in an endless loop until CPU0 has copied all code from EPCS to RAM for both CPUs and then changed some value in the onchip memory (or used a mutex or mailbox for signalling). But you probably have to modify the scripts for preparing the EPCS contents and bootloader code. Kolja
