20 years agoboa SSL connection problem
I compiled openssl 0.9.7 and enabled SSL in boa. The webserver started, but when I try to connect I get following error: SSL_R_SSL_SESSION_ID_CALLBACK_FAILED Does anybody know what is wrong an...
20 years agoThank you very much!!
under microtronix's boa, passwd can pass. Thank you!! In NiosII IDE, your boa source can't pass compile. I can't understand clearly what you said. Could you explain it. for example:Make sure you have the openssl include files copied to
c:\altera\kits\nios2_51\bin\eclipse\plugins\com.microtronix.nios2linux.uClibc_1.4.0\include There is no .h file in opensll which download from downloadplace. Thank you very much!!!
