20 years agoboa SSL connection problem
I compiled openssl 0.9.7 and enabled SSL in boa. The webserver started, but when I try to connect I get following error: SSL_R_SSL_SESSION_ID_CALLBACK_FAILED Does anybody know what is wrong an...
20 years ago --- Quote Start --- originally posted by nacide@May 31 2006, 08:37 AM in the mean time i could solve the problem myself. it was due to the device /dev/urandom missing.
creating the device in the rootfs solved the problem and ssl works now.
get the boa webserver with auth and ssl working from
my webpage (http://www.8ung.at/nacide_manfred/linuxtutorial.html#boawebserver)
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15724)
--- quote end ---
--- Quote End --- Hi,nacide. Could you tell me something more about how to create boa_passwd? what is it format? How to get crypt password? my source file as follow:
# Boa v0.94 configuration file# File format has changed little from 0.92# version changes are noted in the comments# # The Boa configuration file is parsed with a lex/yacc or flex/bison# generated parser. If it reports an error, the line number will be# provided; it should be easy to spot. The syntax of each of these# rules is very simple, and they can occur in any order. Where possible# these directives mimic those of NCSA httpd 1.3; I saw no reason to # introduce gratuitous differences.
# The "ServerRoot" is not in this configuration file. It can be compiled# into the server (see defines.h) or specified on the command line with# the -c option, for example:# # boa -c /usr/local/boa
# Port: The port Boa runs on. The default port for http servers is 80.# If it is less than 1024, the server must be started as root.
Port 80
# User: The name or UID the server should run as.# Group: The group name or GID the server should run as.
User 0
Group 0
# ServerAdmin: The email address where server problems should be sent.# Note: this is not currently used.
ServerAdmin root@localhost
# ErrorLog: The location of the error log file. If this does not start# with /, it is considered relative to the server root.# Set to /dev/null if you don't want errors logged.
# ErrorLog /dev/null
# AccessLog: The location of the access log file. If this does not# start with /, it is considered relative to the server root.# Comment out or set to /dev/null (less effective) to disable # Access logging.
# AccessLog /log/boa/access_log
# RefererLog: The location of the referer log file. If this does not# start with /, it is considered relative to the server root.# Comment out or set to /dev/null (less effective) to disable# referer logging.
# RefererLog /log/boa/referer_log
# AgentLog: The location of the agent log file. If this does not# start with /, it is considered relative to the server root.# Comment out or set to /dev/null (less effective) to disable# User-Agent logging.
# AgentLog /mnt/jaguar/log/boa/agent_log
# VerboseCGILogs: this is just a logical switch.# Comment out to disable.# VerboseCGILogs
# ServerName: the name of this server that should be sent back to # clients if different than that returned by gethostname -- often# this is www.foo.bar.
# ServerName www.your.org.here
# DocumentRoot: The root directory of the HTML documents.
# DocumentRoot /var/www
DocumentRoot /home/httpd
# ChRoot: Boa root '/' directory. This is useful to improve security of# your system. Don't forget that ALL DIRECTORIES used by boa except logs# must be in this directory. If you need cgi scripts, you must copy shared# libraries to this directory (see ldconfig(8) for more info)
ChRoot /home/httpd
# UserDir: The name of the directory which is appended onto a user's home# directory if a ~user request is recieved.
UserDir public_html
# DirectoryIndex: Name of the file to use as a pre-written HTML# directory index. Please MAKE AND USE THESE FILES. On the# fly creation of directory indexes can be _slow_.#
DirectoryIndex index.html
# DirectoryMaker /usr/local/sbin/boa_indexer
DirectoryMaker /sbin/boa_indexer
# LocalCodepage: Local codepage. This is send to client in 'Content-Type:'# header by default.
# LocalCodepage iso-8859-1
# Codepage: Load codepage conversion table from file. This table will be used# on-the-fly conversion.
# Codepage us-ascii /usr/lib/boa/iso-8859-2/us-ascii
# CodepageByURL: Specify URL prefix codepage. This command is used for manual# codepage selection. For example, http://www.cz.boa.org/asc/document.html# converts /document.html to us-ascii
# CodepageByURL /asc us-ascii
# CodepageByBrowser: Specify codepage by $USER_AGENT. This command is used for# automatic codepage selection. You can use characters '*' and '?' in browser# string. For example, "CodepageByBrowser Lynx/* us-ascii" will send for Lynx# users all documents in us-ascii.
# CodepageByBrowser Lynx/* us-ascii
# KeepAliveMax: Number of KeepAlive requests to allow per connection# Comment out, or set to 0 to disable keepalive processing
KeepAliveMax 100
# KeepAliveTimeout: seconds to wait before keepalive connection times out
KeepAliveTimeout 10
# MimeTypes: This is the file that is used to generate mime type pairs# and Content-Type fields for boa.
MimeTypes /etc/mime.types
# DefaultType: MIME type used if the file extension is unknown, or there# is no file extension.
DefaultType text/plain
# AddType: adds types without editing mime.types# Example: AddType type extension
# Uncomment the next line if you want .cgi files to execute from anywhere
AddType application/x-httpd-cgi cgi
AddType application/postscript ps
AddType application/postscript eps
AddType application/pgp pgp
AddType audio/x-aiff aif
AddType audio/x-aiff aifc
AddType audio/x-aiff aiff
AddType text/plain asc
AddType text/plain txt
AddType audio/ulaw au
AddType video/x-msvideo avi
AddType application/x-bcpio bcpio
AddType application/octet-stream bin
AddType application/x-netcdf cdf
AddType application/x-cpio cpio
AddType application/x-csh csh
AddType application/x-dvi dvi
AddType text/x-setext etx
AddType application/andrew-inset ez
AddType image/gif gif
AddType application/x-gtar gtar
AddType application/x-gunzip gz
AddType application/x-hdf hdf
AddType text/html html
AddType image/ief ief
AddType image/jpeg jpe
AddType image/jpeg jpeg
AddType image/jpeg jpg
AddType application/x-latex latex
AddType application/x-troff-man man
AddType application/x-troff-me me
AddType application/x-mif mif
AddType video/quicktime mov
AddType video/quicktime qt
AddType video/x-sgi-movie movie
AddType video/mpeg mp2
AddType video/mpeg mpe
AddType video/mpeg mpeg
AddType video/mpeg mpg
AddType application/x-troff-ms ms
AddType application/x-netcdf nc
AddType application/oda oda
AddType image/x-portable-bitmap pbm
AddType application/pdf pdf
AddType image/x-portable-graymap pgm
AddType application/x-chess-pgn pgn
AddType image/x-portable-anymap pnm
AddType image/x-portable-pixmap ppm
AddType image/x-cmu-raster ras
AddType image/x-rgb rgb
AddType application/x-troff roff
AddType application/rtf rtf
AddType text/richtext rtx
AddType application/x-sh sh
AddType application/x-shar shar
AddType audio/basic snd
AddType application/x-wais-source src
AddType application/x-sv4cpio sv4cpio
AddType application/x-sv4crc sv4crc
AddType application/x-troff t
AddType application/x-troff tr
AddType application/x-tar tar
AddType application/x-tcl tcl
AddType application/x-tex tex
AddType application/x-texinfo texi
AddType application/x-texinfo texinfo
AddType image/tiff tif
AddType image/tiff tiff
AddType text/tab-separated-values tsv
AddType application/x-ustar ustar
AddType audio/x-wav wav
AddType image/x-xbitmap xbm
AddType image/x-xpixmap xpm
AddType image/x-xwindowdump xwd
AddType application/zip zip
# Redirect, Alias, and ScriptAlias all have the same semantics -- they# match the beginning of a request and take appropriate action. Use# Redirect for other servers, Alias for the same server, and ScriptAlias# to enable directories for script execution.
# Redirect allows you to tell clients about documents which used to exist in# your server's namespace, but do not anymore. This allows you to tell the# clients where to look for the relocated document.# Example: Redirect /bar http://elsewhere/feh/bar
# Aliases: Aliases one path to another.# Example: Alias /path1/bar /path2/foo
# Alias /doc /usr/doc
# ScriptAlias: Maps a virtual path to a directory for serving scripts# Example: ScriptAlias /htbin/ /www/htbin/
# VirtualHost: Maps a virtual host to a directory.# Example: VirtualHost cz.boa.org /html/htdocs/boa/
# VirtualHost www.second.company.com /var/www/second_company/
# Auth: HTTP Basic authorization. Format is "Auth <Directory> <PasswdFile>".# Password file should be readable _ONLY_ by root or trusted user(s). This file# is opened before boa gives out privs.# Example: Auth /secret /var/www/secret.passwd
Auth / /etc/boa_passwd /etc/boa_passwd is : melvin $1$$xnB8I.j83d1doTGExRA.i. $1$$xnB8I.j83d1doTGExRA.i. is copied from /etc/passwd which created by command passwd in uclinux. Please give me some advice!!!!!!!!
