16 years agoBoa configuration
Hi, When I execute boa I receive an error as: --- Quote Start --- [30/Nov/1999:00:14:38 +0000] No such user: root --- Quote End --- I have tried to configure boa but I...
16 years agoHi,
I haven't solutioned that problem I gave up. But the other day I found a post about this theme. It suggested to comment two lines of code(Lines that give the error). These lines are relationed with ethernet's security, so boa can run without them. I don't know if it goes, I have to prove it during this week. In /src/boa.c in function drop_privs, comment these lines:
DIE("getpwuid");
DIE("initgroups");
Please keep inform if you find the solution for this trouble, I also will try it. Thanks
