16 years agoBluetooth Module interfacing using AT Commands with NIOS II
Hello everyone, I have a CycloneII DE2 Board. Using NIOS II (Assembly and C), is it possible to interface with a Bluetooth module, say some custom one which I would buy from some vendor, which...
16 years agoThanks for the response!
Any specific model you suggest to start with? Also, is there any NIOS II Assembly code that I can play around with. Or maybe C code, to send the AT command into the module? The Bluetooth is optional in the device, so I think a very normal features module would fit for this. Thanks again =)
