11 years agoBitbake Output Packages
Hey! Referring to [1], I was wondering if it is possible to run the bitbake process and only have the green field as output. I would like to have only packages as output and then, later, I wou...
11 years agoer... I think you should be following the standard procedure, you are try to tweak the process?
