14 years agoBit or byte swapping in SDRAM?
Hi, I have an Avalon-ST component sending data to an on-chip FIFO (ST input / MM output), which is read by a Nios CPU. I've verified that the data coming out of my component is valid both on a...
14 years ago --- Quote Start --- What am I doing wrong here? --- Quote End --- Have you written a testbench? If not, you should. Demonstrate the issue in a testbench and post an image of the Modelsim screen shot, or a PDF, along with the code. That'll help clarify what you are trying to describe. Cheers, Dave
