19 years ago
/bin/init hangs
hi all,
I am trying to boot uclinux on 2s60 board. where my kernel is hanging
moment it calls /bin/init. I have build uclinux with changed memory layout
where base addresses and irq number differs then default memory layout .sof and .ptf files
given by microtronix. Also I have remover support for compact flash in my case.
I can boot uclinux build from microtronix .sof and .ptf file on the board with similarly
generated file system. I tried "root=/dev/mtdblock0 ro" as well as nfs boot with root=/dev/nfs ro,
and seems fine (nfs boot init gives error with init: execv failed, but get login and prompt ok) .
But when I give my memory layout sof and ptf file the compilation is successful but kernel
get hangs when he calls /bin/init.
Any one has any idea why it is happing so???
Do I need to build new busybox ???
Is it not possible to boot uclinux with custom memory layout on Altera boards ??
Do I need to change my quartus-II 4.2 and nios-II 1.1 versions ???
Any suggestion where I am going wrong ???
If any one need I can post my sof, ptf and nios2_system.h files.
thanks in advance
Ankur
    --- Quote Start ---
    originally posted by hippo@May 7 2006, 02:54 AM
    which linux distro do you use?
    check your buildroot/build_nios2/staging_dir/bin,
    are there the cross gcc?
    i would suggest you put the buildroot dir in your home dir as user. ie ~/buildroot .
    please try, rm -rf ~/buildroot/toolchain_build_nios2
    and make again.
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15138)
    --- quote end ---
    --- Quote End ---
    hi hippo and all,
    I am using redhat - 9 on my host system for develop.
    Cross gcc is not there in buildroot/build_nios2/staging_dir/bin....
    Now I have shifted buidroot dir in my home dir but still its failing with same error...
    I read that redhat-9 "make" has some problem ... do I need to update my host system linux-ver to some Fedora version.
    Do I need to build cross-uclibc-gcc by my self or buildroot will do it for me ????
    thanks
    Ankur
    --- Quote Start ---
    originally posted by ankur+may 8 2006, 04:22 pm--><div class='quotetop'>quote (ankur @ may 8 2006, 04:22 pm)</div>
    --- quote start ---
    <!--quotebegin-hippo@May 7 2006, 02:54 AM
    and make again.
    --- quote end ---
    --- Quote End ---
    hi hippo and all,
    thanks
    Ankur
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15183)</div>
    [/b]
    --- Quote End ---
    The "make" of redhat is too old.
    You should use Fedora Core 5.
    The buildroot will build the cross gcc.
    I have prepared the binary buildroot tools, you can try it without building buildroot.
    http://forum.niosforum.com/forum/index.php?showtopic=3879 (http://forum.niosforum.com/forum/index.php?showtopic=3879)
    hi hippo and all,
    I tried your binaries and it worked http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
    What I actually did is ... on my redhat-9 system I untared your pre compiled gcc and stuff, then through your already build file system&#39;s help I build my kernel and it worked perfectly fine.
    I can now see file system in ram file system boot. But still facing some issues with nfs root ....
    It doesn&#39;t look like any problem with buildroot or file system ....
    I am getting following error while booting same kernel with nfs boot support enable
    mm/vmscan.c 736 Kernel BUG!
    mm/vmscan.c 738 Kernel BUG!
    What I found is I have enabled bit swaping feature in my nios processor in fpga configuration. Next I will try disabling it and will update result on forum.
    Thanks for all your help
    Ankur
