20 years ago/bin/init hangs
hi all, I am trying to boot uclinux on 2s60 board. where my kernel is hanging moment it calls /bin/init. I have build uclinux with changed memory layout where base addresses and irq numbe...
20 years ago --- Quote Start --- originally posted by lefred@May 4 2006, 07:53 PM hi all,
it seems i have a similar problem with my 2c35 board.
it's about one week i try to find a solution ... please help !!!! :-)
the boot screen looks like that:
linux version 2.6.11-uc0 (fleconte@frmtg01d57967) (gcc version 3.4.1 (altera ni
s ii 5.1 b73))# 12 wed may 3 15:48:40 2006
uclinux/nios ii
altera nios ii support © 2004 microtronix datacom ltd.
built 1 zonelists
kernel command line: root=/dev/mtdblock0 ro
pid hash table entries: 256 (order: 8, 4096 bytes)
dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
memory available: 30592k/32768k ram, 0k/0k rom (1531k kernel code, 302k data)
mount-cache hash table entries: 512 (order: 0, 4096 bytes)
net: registered protocol family 16
jffs2 version 2.2. © 2001-2003 red hat, inc.
serial: jtag uart driver $revision: 1.4 $
ttyj0 at mmio 0x822208b0 (irq = 1) is a jtag_uart
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered
ramdisk driver initialized: 16 ram disks of 4096k size 1024 blocksize
smc_probe: 85000 khz nios
smsc lan91c111 driver (v2.1), (linux kernel 2.6)
eth0: smc91c11xfd(rev:2) at 0x82210300 irq:6 memsize:8192b nowait:0 addr: 00:07
ed:0f:07:74
altera ndk flash (amd): found 1 x16 devices at 0x0 in 8-bit bank
amd/fujitsu extended query table at 0x0040
altera ndk flash (amd): cfi does not contain boot bank location. assuming top.
number of cfi chips: 1
cfi_cmdset_0002: disabling erase-suspend-program due to code brokenness.
cmdlinepart partition parsing not available
redboot partition parsing not available
using altera ndk partition definition
creating 4 mtd partitions on "altera ndk flash (amd)":
0x00400000-0x00c00000 : "romfs/jffs2"
0x00000000-0x00400000 : "loader/kernel"
0x00c00000-0x00d00000 : "user configuration"
0x00d00000-0x01000000 : "safe configuration"
net: registered protocol family 2
ip: routing cache hash table of 512 buckets, 4kbytes
tcp established hash table entries: 2048 (order: 2, 16384 bytes)
tcp bind hash table entries: 2048 (order: 1, 8192 bytes)
tcp: hash tables configured (established 2048 bind 2048)
net: registered protocol family 17
vfs: mounted root (romfs filesystem) readonly.
freeing unused kernel memory: 60k freed (0x41aa000 - 0x41b8000)
kernel panic - not syncing: no init found. try passing init= option to kernel.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15036)
--- quote end ---
--- Quote End --- The best suggestion, try the buildroot guide and work on a Linux box, it is easier to use and customize. http://forum.niosforum.com/forum/index.php?showtopic=3174 (http://forum.niosforum.com/forum/index.php?showtopic=3174)
