20 years agoBINFMT_FLAT: bad header magic
Hello everyone When I want to run a application software on NIOS II & uCLiunx, I got these fault message, how could I solve it? <div class='quotetop'>QUOTE </div> --- Quote Start --- ...
20 years ago --- Quote Start --- originally posted by goral@May 3 2006, 12:12 PM <div class='quotetop'>quote
--- quote end ---
--- quote start ---
yes, you can use usb disk.
if you want jffs2, read step7,8 in the buildroot guide. --- Quote End --- Hi hippo But when I run it on my usb disk, I got the same message, how I config it? Thanks! <div align='right'><{post_snapback}> (index.php?act=findpost&pid=14980)</div> [/b] --- Quote End --- Check jay's thread, http://forum.niosforum.com/forum/index.php?showtopic=3763 (http://forum.niosforum.com/forum/index.php?showtopic=3763) First check your apps size, niso2-linux-uclibc-flthdr apps check your memory usage with "free" or "cat /proc/meminfo" Did the apps fail in program loading or runtime?
