20 years ago
binary of buildroot tools
I prepared the tools and includes from buildroot. You can use it to compile kernel and apps.
You don't have to download and build buildroot. (but you should try it later, when you got more experiences)
These are the binary tools and rootfs.
http://hungryhippo.myweb.hinet.net/nios2gcc.tar.bz2 (http://hungryhippo.myweb.hinet.net/nios2gcc.tar.bz2)
http://hungryhippo.myweb.hinet.net/nios2rootfs.tar.bz2 (http://hungryhippo.myweb.hinet.net/nios2rootfs.tar.bz2)
or find them on Jhdar's site, (thanks a lot to his help)
http://via.fps-tech.org/snapshots/nios2/ (http://via.fps-tech.org/snapshots/nios2/)
su - # your root passwd
tar jxf nios2gcc.tar.bz2 -C /
exit
cd ~
tar jxf nios2rootfs.tar.bz2
The cross gcc tools will be in /opt/nios dir.
The rootfs with busybox will be in ~/rootfs and ~/download/rootfs_list .
Then setup the PATH for the cross gcc,
PATH=$PATH:/opt/nios2/bin
Try out,
nios2-linux-uclibc-gcc -v
Then try build kernel and apps as in the buildroot guide.
    --- Quote Start ---
    originally posted by hippo@May 8 2006, 04:26 AM
    i prepared the tools and includes from buildroot. you can use it to compile kernel and apps.
    you don't have to download and build buildroot. (but you should try it later, when you got more experiences)
    these are the binary tools and rootfs.
    tar jxf nios2gcc.tar.bz2 -c /
    exit
    cd ~
    then setup the path for the cross gcc,
    path=$path:/opt/nios2/bin
    try out,
    then try build kernel and apps as in the buildroot guide.
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15174)
    --- quote end ---
    --- Quote End ---
    That&#39;s a good work, I&#39;ll try it out after I finish the buildroot.
    Hi,the link doesnot work.I cannot connect to it and download the binary of buildroot tools.
    --- Quote Start ---
    originally posted by xunios@May 8 2006, 06:43 PM
    hi,the link doesnot work.i cannot connect to it and download the binary of buildroot tools.
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15189)
    --- quote end ---
    --- Quote End ---
    It may be blocked in your country.
    I will try to find others.
    Do you have a ftp site which I can upload? Send it to me with PM.
