21 years agobin2flash problems
Hello, I'm trying to upload a linux kernel image to the Microtronix Stratix development board. The "Nios II Linux Quickstart Guide" says to right click on the build/vmlinux.bin file and sel...
21 years agoHi, there is a bug that leaves out an attribute in one of the tags in the <project>.stf file when you apply changes in the project property page.
To remedy this, you can open up the <project>.stf file in an editor and addoffset='0x0' to the location_on_target tag. So your tag should look like this: <location_on_target offset='0x0'> Save these changes and you should be able to upload the kernel image without a problem. (note: the same problem will occur when applying changes in a filesystem project's property page; for a filesystem project, the offset should be 0x200000) This bug will be corrected in the next release of the Nios II Linux Distribution.
