21 years agobin2flash problem
I have use bin2flash command to convert a .bin file( a picture) to .flash file with the parameter --location .Then I use the nios2flash to download the .flash file to flash.But when I run the program...
21 years agoHi BadOmen
I have check the configure information.It is correct.I think if the method that I use the UltraEdit software to convert the .bmp to .bin have problem.Because altera corporation don't provide the tools. Now I have a problem again.Why I use the bin2flash command to transform three .bin files each 301k or two .bin files the same content ,but the output file .flash is the same big 752K. Thank you.
