16 years agobin2flash, offset is larger than flash memory span
Hi, I'm using the flash programmer to download a binary raw image file to the epcs4 flash. When I set the offset as 2048(which is the total page number of epcs4, 512K/256) or a larger value,...
16 years agoHi, have you resolved your question? I have the same problem, unable to program a binary file at offsets larger than 2047.
One thing I know, is that 2048 is address span of the epcs_controller module, and the programmer takes it as flash memory span. When I was using version 8.0, there were no such problems. I am considering to return to 8.0.
