13 years agoBidirection port (PIO) in uClinux
Hi all, does somebody design and program, in which is using pio core in bidirection mode ? I need to communicate between two FPGAs with one control bus (in output pio mode) and bidirection ...
13 years agoAre you sure that your IO_PIO define is the correct address? Sometimes when you regenerate your SOPC/QSYS system, base addresses of some components can change.
Is the PIO device getting its clock?
