14 years ago
Best way to do No-MMU kernels?
I am using the 20100621 distribution. Because I wanted a no-MMU kernel, I switched to the test-nios2 branches under linux-2.6 and uClinux-dist. This allowed me to successfully make and run a zImage on my board (DE2-115). Following the instructions, I then did ./update in nios2-linux. After that make complains that the assembler doesn't understand the initda instruction.
There was a suggestion elsewhere on the forum that this means that the toolchain assembler is old. I'm using the no-MMU toolchain nios2gcc-20080203.tar.bz2.
Can I find a newer no-MMU toolchain?
Should I be using a different distribution than 20100621?
Should I re-install 20100621 and just skip the update?
D.W. Lynn
