19 years agoBest / Simplest OS for TCP/IP
Hi Folks, What OS would people recommend a newbi implement on his Nios-II system, so that he can run TCP/IP, UDP, Ethernet etc. I am looking for an OS with the most support / devkit / Foru...
19 years ago --- Quote Start --- originally posted by devans@Oct 31 2006, 09:33 PM hi folks,
what os would people recommend a newbi implement on his nios-ii system, so that he can run tcp/ip, udp, ethernet etc.
i am looking for an os with the most support / devkit / forum experiance.
uclinux seems popular, but i have no experiance of implementing an os on nios, so good documentation, tutorials and reference examples are a key concern.
ttfn.
dje
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19048)
--- quote end ---
--- Quote End --- Sure, you should try uClinux. It is not difficult. Please follow the uClinux guide on the Nios Wiki, and try out the prebuild image first. Then setup a Linux PC, install the binary toolchains and uClinux-dist. You can find with google for documentation, tutorials and reference examples.
