11 years agoBeMicro SDK Simple Socket Server example problem semaphore
Hi, I'm using the Arrow BeMicro SDK and we develop our application based on the Simple Socket Server example. We now need to port our application from SUPERLOOP to MicroC/OS-II version. While in D...
11 years agofound how to go further (Qsys related). Now I'm at that point :
InterNiche Portable TCP/IP, v3.1 Copyright 1996-2008 by InterNiche Technologies. All rights reserved. prep_tse_mac 0 Your Ethernet MAC address is 00:07:ed:01:23:45 Static IP Address is 192.168.1.2 prepped 1 interface, initializing... [tse_mac_init] INFO : TSE MAC 0 found at address 0x05000800 INFO : PHY National DP83848C found at PHY address 0x01 of MAC Group[0] INFO : PHY[0.0] - Automatically mapped to tse_mac_device[0] INFO : PHY[0.0] - Restart Auto-Negotiation, checking PHY link... INFO : PHY[0.0] - Auto-Negotiation PASSED MARVELL : Mode changed to RGMII/Modified MII to Copper mode MARVELL : Enable RGMII Timing Control MARVELL : PHY reset INFO : PHY[0.0] - Checking link... INFO : PHY[0.0] - Link not yet established, restart auto-negotiation... INFO : PHY[0.0] - Restart Auto-Negotiation, checking PHY link... INFO : PHY[0.0] - Auto-Negotiation PASSED INFO : PHY[0.0] - Link established INFO : PHY[0.0] - Speed = 10, Duplex = Full OK, x=12, CMD_CONFIG=0x00000000 MAC post-initialization: CMD_CONFIG=0x06000203 [tse_sgdma_read_init] RX descriptor chain desc (1 depth) created mctest init called IP address of et1 : 192.168.1.2 Created "Inet main" task (Prio: 2) Created "clock tick" task (Prio: 3) Simple Socket Server starting up [sss_handle_receive] reset connection [sss_task] Simple Socket Server listening on port 3000 Created "simple socket server" task (Prio: 4) [MicroC/OS-II]: See STDERR for expanded diagnosis translation. [MicroC/OS-II]: Expanded Diagnosis: Failed to create SSSLEDLightshowSem. . [MicroC/OS-II]: See STDERR (FAULT_LEVEL is SYSTEM). [MicroC/OS-II]: FAULT_LEVEL is SYSTEM [MicroC/OS-II]: FATAL Error, Restart required. [MicroC/OS-II]: Locking scheduler - endless loop.
