12 years agobattery backup sram
Hi I'm working on Cyclon4Gx FPGA Project and I have a problem with the battery backup ram. Every time I reset the software the memory is always erased. In the past I worked on a similar cyclo...
12 years agoThe battery is ok, I did a couple of tests yesterday and I found that the data are cleared by system startup . If i save a variables with the IOWR instruction outside the map of linker the variables are not erased, I think the alt_load function erases all the section (.text .rwdata etc..) but i don't understand how to configure the bsp setting to avoid this. I have the reset vector , .text, . rwdata , .rodata and the other section in sram.
