14 years agoBasic NIOS II interrupt.
I am getting the warning. --- Quote Start --- warning: implicit declaration of function 'alt_irq_register' --- Quote End --- Call in code is alt_irq_register(CODEC_SIM...
14 years ago --- Quote Start --- Search the headers for the definition of alt_isr_func, probably doesn't quite match the function you supplied. Or my 'trick', add -E to the gcc command file and then open the .o file in a text editor and search through the pre-processed output. (Might be difficult from the IDE) --- Quote End --- From alt_irq.h all I can see is this. # ifdef ALT_ENHANCED_INTERRUPT_API_PRESENT typedef void (*alt_isr_func)(void* isr_context); # else typedef void (*alt_isr_func)(void* isr_context, alt_u32 id); # endif Hmmm...
