11 years agobasic doubts about altera FPGA NIOS II
i have recently purchase altera's fpga and purchase from china NIOS II SOPC FPGA A-C2FB. i burn the configuration file in the board. it run only ones and after reset it run the default code.
11 years agoThere are tutorials out for several configuration flash methods. You first need to find out how your board is being configured. Check the schematic and the data sheet for the flash chip. Then look at the altera configuration handbook and see if you can spot what method is being used. Normally this info is all in the dev board documentation.
