AXI4 DMA Master Error
Hi @Scot
I provide overall details about active_ascon IP
Allow me to mention my issue again: WRITE BURST is being refused by slave (onchip_memory2_2)
1. Block Diagram
* Function of partial blocks
+ RD_CRF: store config (DMAC config + ASCON config) read from source memory and generate info for WR_REQUEST block
+ STORE_CKN_AD: store those data such as: ascon config, KEY, NONCE, AD, TEXT, TAG (using fifo)
+ FORMAT_DATA: format data read from source memory to run ASCON function (ASCON is algorithm that includes AEAD & HASH)
+ other remaining blocks: function is clearly presented through their name.
2. Data Frame & Timing Diagram
- Data frame (stored in source memory)
- Timing Diagram
3. WR REQUEST BLOCK
- WR_BURST GENERATOR RTL CODE
*Note: I only use information as follows
+ size: 3'b010 (always write 1 word (4 bytes) each transfer)
+ burst: 2'b01 (only use INCR burst)
- Manprocoder1 year ago
Allow me to update WR_REQUEST block.
Exact block I am using below:
