20 years agoavalon to avalon bridge
I try to use the avalon to avalon bridge from Longshot (see projects page). the bridge is used to cross clock domains for a number of slower peripherals. The problem is that as soon I connect an interrupt with the bridge, the SPOC builder generates an error :# 2006.09.04 16:46:16 (*) Making arbitration and system (top) modules.
ERROR:
slave clock_2/in is missing parameter 'Base_Address'
255
Error in processing. System NOT successfully generated. Any idea ?2 Replies
I would have to see you .ptf file to see what is going on.
longshot --- Quote Start --- originally posted by svhb@Sep 4 2006, 10:01 AM hi,i try to use the avalon to avalon bridge from longshot (see projects page).
the problem is that as soon i connect an interrupt with the bridge, the spoc builder generates an error :
# 2006.09.04 16:46:16 (*) making arbitration and system (top) modules. error: slave clock_2/in is missing parameter 'base_address' 255 error in processing. system not successfully generated.any idea ?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18059)</div> --- Quote End ---
I putted here :
http://users.telenet.be/svhb/std_2c35.ptf (http://users.telenet.be/svhb/std_2c35.ptf) It is a bit a hacked version of the CycloneII evaluation boards standard design. Not a real product design yet.
