17 years agoAvalon OpenCores MAC 10/100 + µClinux
Hi all, Sorry for the previous post... I'm working on the implementation of a Boa embedded webserver using µClinux on the baseboard DBM_3C40 (Cyclone III / Nios II), with a Marvell 88E...
17 years ago<div class='quotetop'>QUOTE (Gaz @ Jul 30 2009, 10:49 AM) <{post_snapback}> (index.php?act=findpost&pid=23348)</div>
--- Quote Start --- Hi, Im using the same board with the same IP with uClinux but can't seem to get it working. I dont understand how the marvell chip has an 8bit rx/tx bus but the opencore ethernet MAC IP has only 4 bits rx/tx? When i start uClinux up and type 'ifconfig eth0 up" one of the messages it gives me is jabber... which I think is related to too many packets? Ive tried to connect the system as you have done in your screen shots (I hope thats ok). What did you do with the remaining erxd pins?[/b] --- Quote End --- I simply connected the remaining etxd pins "etxd[7..4]" to the ground :rolleyes: Concerning the 8-bits / 4-bits problem, you should take a look on this two pages : http://en.wikipedia.org/wiki/media_independent_interface (http://en.wikipedia.org/wiki/media_independent_interface) -> used by the OpenCores MAC http://en.wikipedia.org/wiki/gigabit_media...ndent_interface (http://en.wikipedia.org/wiki/gigabit_media_independent_interface) -> used by the Marvell PHY
