12 years agoAvalon-MM-Slave address alignment
Hi All I have aquestion regarding the address alignment of a an-MM slave. My MM-Save has an avs_readdata and avs_writedata port each 512 bit wide. Now I'm trying to write the custom prip...
12 years agothanks for your answer!
--- Quote Start --- But it won't generate bursts longer than a cache line. . --- Quote End --- The cache line is defined as 32, but the Nios refuses to make bursts longer than 8. I'd be perfectly fine with a 32-wide burst. This applies to both read and write bursts. :(
