12 years agoAvalon-MM-Slave address alignment
Hi All I have aquestion regarding the address alignment of a an-MM slave. My MM-Save has an avs_readdata and avs_writedata port each 512 bit wide. Now I'm trying to write the custom prip...
12 years agoHi dsl
You're right, I now changed my Avalon MM slave Custom peripheral to us it with burst transfer. However, I don't know how the _regs.h file needs to look. For example, how to I write my 32bit width data over the IOWR() makro on the right position of my 512bit wide slave avr_writedata? Do I need to set the bytenable or address bits? But how? Thank you for your help
