12 years agoAvalon-MM-Slave address alignment
Hi All I have aquestion regarding the address alignment of a an-MM slave. My MM-Save has an avs_readdata and avs_writedata port each 512 bit wide. Now I'm trying to write the custom prip...
12 years agoSince the Nios can only do 32bit Avalon master cycles, you really don't want a 512bit wide slave.
You'll only get a bus width adapter that will assert the revelant byte enables for the address. It is probably much better to write a 32bit slave. I'm not sure what your problem with IORD() and IOWR() is - they are just wrappers that generate ldio and stio instructions. As such their definitions aren't entirely useful. Most device driver writers use C structures to map device registers, it is much less error prone than using integer offsets.
