20 years agoAvalon Master write does not write
My sopc modul has 3 Interfaces. avs_slavereg that holds the registers the nios reads from and writes to to control this modul avm_readmaster a read only a master that reads data from sdram...
20 years agowe enabled for both master the access to offchip 8but sram.
if we write to sram, the writes are executed and offchip sram holds the data :-) if we write to sdram, nearly no write is executed :-( same master, same source, same compilation, only different target. in both cases write is asserted. for ext. sram we see waitrequests for sdram we never see waitrequests. Michael Schmitt
