21 years ago
avalon master mode problem
I use the avalon master mode to transfer data
from fpga fifo to sdram.
To debug this design, i use two fifo, the content is same betwen the two fifo.
The fifo mode is show-ahead,
The two fifo is rxfifo and debugfifo.
The data in debug fifo is(i only list 30 data)
temp is 420 temp is 1014 temp is 2017
temp is 301b temp is 4020 temp is 5fde
temp is 6000 temp is 7000 temp is 8000
temp is 9014 temp is a000 temp is b000
temp is c000 temp is d000 temp is e000
but when i printf the sdram data(It should be same with the
the fifo data if
temp is 420 temp is 1014 temp is 4b69d587
data 3 is wrong.
????? Why?? do you encounter the same problem???
I think this is the sdram controller problem .
the following is my hdl code
assign sdram_interface_writedata = rxfifo_dataout_reg ;
always@(posedge clk or negedge rst_n)
begin
if(!rst_n) rxfifo_dataout_reg <= 32&#39;b0;
else rxfifo_dataout_reg <= rxfifo_dataout;
end
always@(master_active or sdram_interface_waitrequest)
begin
if(master_active)
begin
if(!sdram_interface_waitrequest) rxfifo_rdreq = 1&#39;b1;
else rxfifo_rdreq = 1&#39;b0;
end
else
begin
end
end
begin
if(!rst_n) begin sdram_interface_address[23:0] <= 24&#39;b0; sdram_interface_write_n <= 1&#39;b1; sdram_interface_read_n <= 1&#39;b1;
sdram_interface_address[24] <= 1&#39;b1;
counter <= 22&#39;b0;
end
else begin
if(master_active)
begin
sdram_interface_write_n <= 1&#39;b0;
begin
sdram_interface_address[23:0] <= {counter,2&#39;b0};
counter <= counter + 1&#39;b1;
end
else
begin
counter <= counter;
end
end
else
begin
sdram_interface_address <= 25&#39;b0;
end
end
end
rx_fifo rx_fifo_inst(.data({frame_buffer_address[19:0],frame_buffer_dataout}),.wrreq(fra
me_buffer_write),.rdreq(rxfifo_rdreq),
.clock(clk),.q(rxfifo_dataout),.empty(rxfifo_empty));
debug_fifo debug_fifo_inst(.data({frame_buffer_address[19:0],frame_buffer_dataout}),.wrreq(
frame_buffer_write),.rdreq(debugfifo_rdreq),
.clock(clk),.q(debugfifo_dataout));
1 Reply
    I change my HDL code.
    I add an wait state when i finish write two data.
    And this time, the result is right,
    I believe there is a bug in SDRAM controller.
    When i want to write three data, the third data is wrong.
