21 years agoAvalon master and IRQ's
Hi, I’m trying to create a bridge between a TI TMS320F2812 DSP data bus and the Avalon bus. The idea is to use Avalon peripherals and connect them to an TI DSP. I created a Avalon master i...
16 years agoHi,
I had a similar situation. Workaround was to utilize such a UART where you can use it's interrupt line as an output to the SOPC design, thus combining more than one INT. In the Top Level of your design - you could build some small logic which would cascade these INT lines (whatever No. of INT you have) into one common int line after a simple logic AND (and whatever logic level you need) - out to your DSP. For reading the statuse (the INT source): These lines can be routed back to you SOPC Design as inputs to a PIO module (mapped as a register), so you can later read it's content's by the Master, anytime. Hope that helps.. Haim
