20 years agoAvalon Interface Master Port
If there are two masters which access one slave,what happend can be?
is there any setting to setup which master is first or second?2 Replies
Hi suway1219,
> If there are two masters which access one slave,what happend can be? > > is there any setting to setup which master is first or second? Read the section entitled "Arbitration for Multi-Master Systems" in the Quartus II Handbook, Volume 4: "SOPC Builder". It will probably answer your questions. Regards, --Scott - Altera_Forum
--- Quote Start --- originally posted by smcnutt@Apr 13 2006, 03:09 PM hi suway1219,> if there are two masters which access one slave,what happend can be?
read the section entitled "arbitration for multi-master systems" in the
quartus ii handbook, volume 4: "sopc builder". it will probably answer your
questions.
regards,
--scott
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14347)
--- quote end ---
--- Quote End --- Thank you very much!
