17 years agoAvalon FrameBuffer
Hi
I'm new here, I could use a litle help I have a Cyclone III development board and do use Quartus 9 and Nios II 9 I have added a OLED 480x272 display to the port of the Cyclone III board I did some tweek omn the pong game from fpga4fun and had it to work with the Oled display :-) Then I moved to the VIP In the SOPC I have a Test Pattern Generator (720x576) => Scaler (480x272) => Frame Buffer => Color Plane Sequeenser => Clocked video out my sopc (http://www.tech2net.dk/stuff/oled_sopc.jpg) It works fine ... then I added a Nios II CPU and onchip_mem and Jtag and now I have mde some simple C code controlling the scaler and it works fine My next test was to load in a image to the frame buffer ( I strat with something simple ...a simple RGB colorbars) this does NOT work In the SOPC I can see my DDR2 ram start at 0x08000000 .... so I want to write some data to the framebuffer for 480x272 I have seen in another example they do use this for 640x480 (sure I have tried to adjust to 480x272) IOWR(VGA_BASE, 0, (unsigned int) IMAGE_MEMORY); // set the base address of the image IOWR(VGA_BASE, 1, 0x028001E0); // configure the VGA controller for a 640x480 image IOWR(VGA_BASE, 2, 0x0001); // turn on the VGA controller with interrupts disabled. What should the VGA_BASE be? r = 0xf800; g = 0x07e0; b = 0x001f; for(j=0;j<640*(480+1);j+=640) for(i=0;i<640;i++) if(i<640/4) *((volatile short *) IMAGE_MEMORY + i + j) = r; else if(i<640/2) *((volatile short *) IMAGE_MEMORY + i + j) = g; else if(i<3*640/4) *((volatile short *) IMAGE_MEMORY + i + j) = b; else *((volatile short *) IMAGE_MEMORY + i + j) = 0xffff; I need to know what are needed when try to load data to the Avalon framembuffer? Do I understand it correct I first have to stop the old frame and the make a new then define width x height and point on mem start and the load in some data and the start the frame? Please advise Thank you WiljanNo RepliesBe the first to reply
