13 years agoAvalon bus with 2 Avalon_MM_ Slaves fails to work (works fine with 1...)
Hi All, I have designed an Avalon bus with 1 Master and 1 Slave, it works greate. I can do write and read just fine. OK, so I added another Master and another Slave, the first Slave at b...
13 years agoI would avoid using chipselect for starters. This is from the spec, pay extra attention to the last sentence:
"When present, a slave port ignores all Avalon-MM signals unless chipselect is asserted. chipselect must be used in combination with read or write. The chipselect signal is not necessary; Altera does not recommend using it." Have you simulated your system to see what is happening at the fabric level? That's typically where I start when debugging issues that resemble this.
