20 years agoAvalon bus timing question
I'm trying to understand exactly when the chip select and read/write lines on the Avalon bus change. For a standard write transfer the timing shows the chip select coming high after the address a...
20 years agoIf you use the waitrequest signal, you can stall the bus altogether and you decide when the transfers occur. Is this the functionality you are looking for?
