21 years agoAvalon Bus Behaviour
Folks, Came across an interesting problem in my custom peripheral logic and was wondering what the Avalon bus Address bus state is between bus cycles? The book shows a black bar signifying "und...
21 years agoActually address can, and does, jump around quite a bit. It is registered, but not registered "just for the view of the slave" (if that makes any sense). The general idea is to reduce muxing (which eats LEs and slows F-max) as much as you can... in the simple case of a single master and many slaves, you will probably see the address to all slaves indicative of what the master is doing.
If I remeber correctly read, write, and chipselect are the only qualified signals delivered to the slave. The Avalon spec can confirm this.
