16 years agoAvalon Address Decoding Chipselect assertion
Hello Can we assert the chipselect signal, which is assigned by the Avalon Address Decoding, in 'C' by ourselves? Can we change Avalon signals behavior in Nios II by coding? Thanks,
16 years agoIt's performed in the hardware. When a master performs a read or write to a valid address in the slave memory space the chipselect will be asserted.
Chipselect is also an optional signal since you can just OR the read and write signals coming into the slave port to get the exact same functionality.
