20 years ago"available memory space 0 k" what's the problem
I build the Kernel project successfully.On the next step of "building filesystem", as I select my ptf file,IDE show the warning: available memory space 0 k .(Flash on my board is 4M ) ,why?
Thanks.2 Replies
hanwl,
I had this same issue before in this filesystem thread (http://www.niosforum.com/forum/index.php?showtopic=2307&hl=keplin). Without knowing more about your system, I'm unsure if this relates completely to what's causing your issue. - Matt - Altera_Forum
Thanks kelin
I will try again with your way.
