21 years agoautomunting the usb memory key
hi,
i enable the hotplug in the general setup menu in the kernel configuration wizard and updated the file system with the hotplug package. What else do i need to automaticly mount the usb memory stick when i plug-it in on uClinux. this is the message when i plug the usb memory key --- Quote Start --- # usb 1-1: new full speed USB device using address 2 usb 1-1: Product: Cruzer Micro usb 1-1: Manufacturer: SanDisk Corp. usb 1-1: SerialNumber: 0000930987 BINFMT_FLAT: Loading file: /sbin/hotplug BINFMT_FLAT: Loading file: /sbin/hotplug scsi0 : SCSI emulation for USB Mass Storage devices BINFMT_FLAT: Loading file: /sbin/hotplug Vendor: SanDisk Model: Cruzer Micro Rev: 2033 Type: Direct-Access ANSI SCSI revision: 02 BINFMT_FLAT: Loading file: /sbin/hotplug SCSI device sda: 256000 512-byte hdwr sectors (131 MB) sda: assuming Write Enabled sda: assuming drive cache: write through BINFMT_FLAT: Loading file: /sbin/hotplug sda:<7>usb-storage: queuecommand called sda1 BINFMT_FLAT: Loading file: /sbin/hotplug Attached scsi removable disk sda at scsi0, channel 0, id 0, lun 0 BINFMT_FLAT: Loading file: /sbin/hotplug2 Replies
probably you can check your /sbin/hotplug script to see what else it needs.
i still can't make the hotplug works...
i thing i'm not installing it well... does anybody knows hoy to install that package to be compiled and uploaded in to the flash. regards
