21 years agoAutomatically create SREC file after build
I want to automatically create a SREC file from the elf file after the build. I know the command to use is as follows: nios2-elf-objcopy -O srec MyProg.elf MyProg.srec The thing that I do...
21 years agoThanx, it gets me closer, but I still have a problem. I have a 3 projects in my Workspace. It gives me an error when I build because one of the projects builds before the the desired elf file is created. Therefore, I get errors in the build. Is there a way to only run my little make file for a particular project?
After a little more investigating, I came across 'External Tools Builder' in properties. I tried just writing a simple shell script that does the nios2-elf-objcopy, but I get an error stating that there was an error in the command line. Not much help from that message http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif The IDE seems to be a lot fuzzy about this. It seems simple what I want to do. I just cannot seem to find the needed info.... Thanks
