17 years agoAutomate FTP
Hello champs, I am trying to write a routine that automates FTP transfers. I was using ftpput in Busybox but it consumes way too much memory. I've seen some examples but they are in ksh...
17 years agoHello,
I've made modifications to my application. Eliminated the recursive part to a single program that fills in the buffers, and verifies whether it should send or not the log file via FTP. However, I met the same problem. I haven't figured out how to substitute the ftpput command, and after it is called a few times, the OS says it doesn't have RAM Space. The ftp client provided in make menuconfig ---> user apps ----> network applications ----> ftp works perfectly and is able to send files. but the user has to input all the data. I was wondering if there is a way to automate that one. My idea is , for example, send "ftp 192.3.1.2" to open it in the console, then wait for some time between instructions, and send the "useraccount", "password", "put /file", and "exit" as if I was writing them on the console. I don't know if this can be made by writing on stdin or something. If this is not possible, I think I would have to program the protocol in a very light way in C. Any chances anyone knows about a routine about this. I've read some, but they are quite difficult for me to follow. Also read about tftp, butn since is is done via UDP, I think I will go along with ftp. Any help is appreciated. Thanks in advance Francisco
