Auto Negotiation FAILED : Nios II Simple Socket server
Hi Avinash!
Hoping you're doing well, I was wondering if the information and project I shared with you were useful to solve the issue.
Please let me know if you have any concerns that I can help you with or if I can push the case to close pending, after do this you'd have a period of 15 days to comment something and it will be automatically opened again.
-Eliath Guzman
Hello Eliath,
Thank you for the fix that you have suggested regarding the name mismatch in the TSE_0. It worked. In the NIOS console, I was being asked to provide the 9 digit serial number present at the back of my board (refer to the screenshot). Is this normal? Because I did not come across this pop up when I was working with the reference design present in the website. Kindly guide us. @Eliath_G_Intel
- APaga16 years ago
Hello Eliath,
In one of the documents present in the website for NIOS II Simple socket server, it was mentioned that in case of issues related to MAC address, we can try typing "255255248".
I have typed that address and it seemed to be working. In fact, any non zero 9-digit address seems to be working. So It shows that the Simple socket server is listening in port no.30 as shown in the screenshot.
But now, when I am trying to open a Telnet server with the IP address 192.168.1.234 and port 30, the connection is not established. I've even tried with 192.168.1.1 but no success.
Kindly help.
Avinash Paga
- Eliath_G_Intel6 years ago
Hello Avinash,
We have two KDB's ( Knowledged Data Base) where you'll find the changes needed on the code to make the project work properly. The connection will be solved too.
Why my Nios® II Simple Socket Server design example fails to auto-negotiate at 1G speed
Why my Nios® II Simple Socket Server (RGMII) design example Ethernet link is down when run on Intel FPGA Development Kits with MARVELL PHY?
Please, apply these changes to your code and test again the connection with the host.
One more thing, when executing the windows command prompt, try to do it as administrator and then make the corresponding test.
Any questions or updates, please do not hesitate and let me know. @APaga1
-Eliath Guzman
- APaga16 years ago
Hello Eliath @Eliath_G_Intel ,
Thank you for your support. We have observed that the auto negotiation is passing at 1G speed and the naming conventions of TSE are according to what it is suggested in the KDB that you have sent. But unfortunately, the ethernet link is still not up. We are getting the below message in the NIOS console at the end:
Simple Socket Server starting up
[sss_task] Simple Socket Server listening on port 30
Created "simple socket server" task (Prio: 4)********************************************************************************************
But still we could not establish a telnet session with IP: 192.168.1.234 and port 30. We are hardware engineers and we are finding it difficult to debug the software portion of the simple socket server. Can you please explain what can be a way to progress further? Thank You!
Warm Regards,
Avinash Paga
