17 years ago
Audio system on DE2 board
Hello!
I use Quartus 9.0 and NIOS 9.0. My project is to implement audio system (actually for first time feedback from microphone to Line-Out) on DE2 board.
I have created with SOPC Builder required system for my purpose:
  • NIOS II Processor
  • On-Chip memory (RAM or ROM)
  • JTAG UART
  • SRAM/SSRAM Controller (up_avalon_sram_0 module)
  • Audio (up_avalon_audio_0 module)
  • Audio and Video Config (up_avalon_audio_and_video_config module)
Audiomodule and audio and video config modules were downloaded from http://www.altera.com/education/univ/materials/ip-cores/unv-ip-cores.html.
So, bdf file was created successfully, software project was created too. But during building pretty plain program (just main function and return) I get this error:
system_description/alt_sys_init.c:75: error: `UP_AVALON_AUDIO_AND_VIDEO_CONFIG_0_CFG_TYPE' undeclared here (not in a function)
system_description/alt_sys_init.c:75: error: initializer element is not constant
system_description/alt_sys_init.c:75: error: (near initialization for `up_avalon_audio_and_video_config_0.type')
I have commented two rows in file alt_sys_init.c:
altera_up_avalon_audio_and_video_config_instance( up_avalon_audio_and_video_config_0, up_avalon_audio_and_video_config_0 );
and this
altera_up_avalon_audio_and_video_config_init( up_avalon_audio_and_video_config_0, up_avalon_audio_and_video_config_0 );
then I can build system, write code for writing and reading fifos. I hear sound per headphones from mic. But additional I hear very big NOISE! So, I think it is related to ignore two rows in alt_sys_init.c file...
Please advice what to do with this issue...
Vytautas
    As i see on your post, the component instance name for "Audio/Video Configuration" in SOPC builder should be up_avalon_audio_and_video_config_0 not up_avalon_audio_and_video_config.
    Hello.
    Sorry, actually name of this instance is up_avalon_audio_and_video_config_0...
    Please find attached picture of nios processor.
    I don't understand who and why needs this constant:
    UP_AVALON_AUDIO_AND_VIDEO_CONFIG_0_CFG_TYPE ??
    Hello.
    Do you have some idea? Something is missign? Also, configuration panel of UP_AVALON_AUDIO_AND_VIDEO_CONFIG IP core is much smaller like it is described in documentation. Please find attached file. Where are additional tabs like describes datasheet: General, Volume Control, Analog Control, Digital Control, Audio Format, Sampling?
    Maybe this issue related to this? Without Digital filter I hear this big NOISE?
    Vytautas
    I have investigated this issue. Now I know that problem is related to wrong IP core. please try to find new version of audio core. new version works well, just need to write correct registers
    Where can I get this newer version of audio core? Thank you for reply
    Version of this core is in altera ftp site. Version is 9.0.
    Now I'm not near PC which has this core
