20 years agoAssignments Editor - migrating between Nios boards
Do you know if there is an easy way to reassign pins for new device in old project?
Right now the only thing I can do is to rewrite everything, dozens or hundreds of pins checking everything in Development Board manual... I'll be thankful for advice http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif1 Reply
Normally what I do is copy the pin assignments from the .qsf file of the full-featured design and just match my pin names. That design is located under kits/nios2/examples/<verilog or vhdl>/<board>/full_featured. Don't do this with the hardware project open since Quartus II may save over your work if it saves your project.
