21 years agoassembly prog
Hi
Has anyone tried to write assembly language programs for nios II processor? If so plz tell me how to start the program i.e., i mean to say are any initial statements required like main() in c-lang. I wrote a sample program as follows but the error is that " %g0 not a valid register" , "%g1 not a valid register". .text MOVI %g0,9 MOV %g1,%g0 NOP So someone please tell me how to overcome the problem4 Replies
Hi rakesh,
You can find example assemble code in u-boot: -cpu/nios2/start.S -cpu/nios2/exceptions.S -lib_nios2/cache.S Regards, --Scott - Altera_Forum
you are writing NiosI asm for NiosII cpu ...
here's something:.file "Main.s" .section .text .align 3 .global main .type main, @function main: //sp <- sp -8 addi sp, sp, -8 //ra -> *(sp +4) stw ra,4(sp) // fp -> *(sp) stw fp,0(sp) // fp -> sp mov fp,sp aaa: //#define LED_BASE 0x00000820 movhi r13, %hiadj(0x00000820) addi r13, r13, %lo(0x00000820) //valeur par bit (1) allume (0) eteint movhi r12, %hiadj(255) addi r12, r12, %lo(255) //allume led stwio r12, 0(r13) call delay1 .... - Altera_Forum
Thankyou smcnutt and slvn. I will be in touch with both of you if i have any more doubts.
rakesh,
if you need more details about assembly and instruction. you should refer to reference and developper handbooks for Nios II. about the prog I did, it's just stupid and incomplete showing you what it looks like. (you were using Nios I assembly in your post I guess). If your SPOC has some leds you can replace Base Led by the address where are mapped your leds, and try something like turning the led on/offfile "Main.s" .section .text .align 3 .global main .type main, @function main: //#define LED_BASE 0x00000820 movhi r13, %hiadj(0x00000820) addi r13, r13, %lo(0x00000820) //valeur par bit (1) allume (0) eteint movhi r12, %hiadj(255) addi r12, r12, %lo(255) //turn led on stwio r12, 0(r13) hope it can help Sylvain
