20 years agoassemble lauguage for nios2
where can i find some unabridged assemble programs which can run well on nios2?
20 years agoThe exception handler is written in assembly, as is crt0.S. However, it's probably best to start with C code and have the compiler generate the assembly for you. You can do this with the "-S" switch. Just Google for details of how to do this, there are many examples on the internet.
Regarding your second question, I think it should be apparent which registers are which by debugging a simple program and glancing at the contents of the registers tab. - slacker
